overtaxed avatar image
overtaxed asked
Putting a transfer switch AFTER a Multiplus?
Is there any problem putting a transfer switch after the MPII (IE, connecting from the "out" side of the 120V system to a transfer switch)? My application here is that I'd like to connect a generator with autostart downstream of the MPII so that if there's an issue with the MP, I can monitor the power and autostart the generator to take over. That covers shore power loss as well as a problem in the inverter itself that prevents power from passing.
Shore power ---- MPII --- Transfer switch ---- Coach
Generator ----------------------^
I'm aware that would prevent my generator from being able to charge the batteries via the MPII, that's not a requirement for my installation (in fact, it's kind of benefit). Just wondering if this is a support topology and/or if anyone has wired this way.
Multiplus-IItransfer switch
mvas avatar image
mvas answered ·
Just verify that the Neutral-Ground bond is correct for both positions of the Transfer Switch.
Kevin Windrem avatar image
Kevin Windrem answered ·
Suggestion: put the generator/shore power transfer switch before the Multi. Then add a manual transfer switch in the position you show above to cover a failure in the Multi, or so you can shut it down for maintenance without disrupting the loads.
Look at my ExtTransferSwitch add-on that will switch the Multi from grid to shore and change the AC input current limit based on the transfer switch position.
https://github.com/kwindrem/ExtTransferSwitch
Wayne avatar image
Wayne answered ·
I have used an Atkinson Electronics GSCM module ($240) in conjunction with a GX Cerbo and MP ll
This gives me the ability to programe in the Cerbo under what load conditions the genset should start, mine is behind the MPll so i dont lose the ability to charge as required as well.
