tdentel avatar image
tdentel asked
Storage mode setting?
Hello.
I have had a Multiplus 2, Cerbo, and 2x 200ah Tycorun Lith batteries in my RV for several months.
I recently connected 720W of solar panels via a Victron 100/50 MTT controller.
After installation the Displayed showed PV input, but the charging seems to stop at about 23% soc and go to "Storage" mode. I plugged in 15A of shore power last night, switched to "charge only".
This AM still at 23% soc and "storage".
Turned off breakers in and out of Solar controller, on and off Multiplus, still in "storage mode.
I must have changed a setting, any help appreciated.
Thanks
smart solar set-up help
anieuwstadt avatar image
anieuwstadt answered ·
Storage mode setting can be found under the charger tab in VEConfigure.
Does the system have a shunt? The shunt is used to accurately track the battery voltage and state of charge the rest of the system. As example the Inverters internal BMS will not be aware of the MPPT charging the battery and therefore will will not know the true State of Charge of the battery.
