ivan avatar image
ivan asked
MQTT subscription to ESS schedules stop answering
Hey!
I'm writing a Python script to fetch data from the ESS schedules automatically.
def on_connect(client: mqtt.Client, userdata, flags, rc):
    client.subscribe("N/%s/system/0/Serial" % portal_id)
    client.subscribe("N/%s/settings/0/Settings/CGwacs/BatteryLife/Schedule/Charge/%d/Day" % (portal_id, num))
def on_message(client, userdata, msg):
    val = json.loads(msg.payload)
    print(msg.topic+" -> "+str(val))
It works fine if I have my Remote Console open on the browser, but if I close it or leave the tab - after a ~0.5-1min mqtt subscription does not return any values.
/system/0/Serial though works fine at any time not depending on an open/close state on the web page.
Have someone faced the same issue?
Maybe there is a way to ping/send keepalive?
I really appreciate any help you can provide.
Best,
Ivan
MQTTpython
paul-campbell avatar image
paul-campbell answered ·
That is the correct proceedure for a "keep alive" bus.
I have an "on_clock" call back which fires off a local clock every second.
I do:
if clock % 5 == 0:
publish_client.publish("venus-home/R/b827exxxxf99/keepalive", "")
ivan avatar image
ivan answered ·
Achieved a "ping" functionality by:
client.publish("R/%s/system/0/Serial" % portal_id)
If there are any better solutions - please share :)
Victron MQTT readme
