robert-sinclair avatar image
robert-sinclair asked
Quattro Voltage issues
Hi just upgraded my whole system 2x 330ah victron batterys 2 lynx distributor 500amp bms 12v_240v 5000w quattro 2 90mm positiveand 90mm negative cables coming from the inverter .now I'm trying to run a ice cream machine in my van now 60 percent of the time its fine the beater motor comes on then the compressor all good but sometimes after the beater moter comes on the compressor switch clicks 2 3 times before it engages but on pass through there is no problem.now if the inverter is set at 230 volt would increasing it to 240 245 v help
nickdb avatar image
nickdb answered ·
Same as your original post, you were advised to fit a soft start. Did you?
Startup current can be many multiples of the power rating.
robert-sinclair answered ·
The installer said a soft start wouldn't help because the moter starts first and it has no problems running the compressor starts second
