mjjordan avatar image
mjjordan asked
Any bluetooth dongle?
If I buy Victron Energy BlueSolar MPPT 75V 15 amp 12/24-Volt Solar Charge Controller, will I be able to use any bluetooth dongle at all? The reason I ask is due to limited space below the intended position, and some generic bluetooth dongles are so small as to be negligible space when fitted.
Bluetooth
You need to use the Victron VE.direct Bluetooth dongle.
https://www.victronenergy.com/accessories/ve-direct-bluetooth-smart-dongle
But why you don't just buy a smart MPPT with build-in Bluetooth?
