petter avatar image
petter asked
Low watt showed in VictronConnect
Im trying to understand is something is wrong with my system or if everything is ok.
The measurements Solar W, V and A showed in Victronix Connect are very low, I'm expecting more.
Just between the MPP changes from Bulk to Absorption in a direct hit from sun shows
In Bulk mode
Solar
42W
34.7V
1.2A
Battery
14.3V
2.7A
In Absorbtion mode
Solar
36W
34.18V
1.1A
Battery
14.29V
2.3
My system setup is quite simple
Battery:
AGM 12 V, 260Ah
Regulator:
mppt 100/20
Panel:
Pmax 280W
Vmpp: 32.5V
Impp: 8.54A
Voc: 38.8V
Isc: 9.25A
TüV: 1500 V DC
Appreciate any feedback
Petter
smart solar set-up help
wkirby avatar image
wkirby answered ·
That seems normal to me.
Once you have reached your set Absorb Voltage of (14.3V I presume), then charge power will start to decline. As the battery is getting full, the current must go down in order to maintain the target Absorb Voltage, otherwise the Voltage would just continue to rise,
If a load appears on the battery, then you should notice the power increase as the MPPT maintains the Absorb Voltage.
The power will decrease even further when you are in Float mode.
It's not possible to continue charging a battery at full power if it is full or getting full.
petter avatar image petter commented ·
Hi and thanks!
I’ve got a lot to learn:-)
