I would like to run a Victron Dongle on my Quattro 48/10000, with an old controller (200).
It helpfully informs me to contact your installer to upgrade to firmware 415+ but those aren't for this controller. Is there a way round this? PCB exchange?
If your Quattro has the old CPU (starting with 19 - 230V or 20 - 120V) there is no way to upgrade that.
As far as I know the PCB with new CPU is not compatible the the old HW.
Thanks Matthias, the quattro is a 20 - 230v. Is the old firmware open source? I could probably program a newer esp-32 or similar and replace the cpu directly.
What would an Installer do to get 415+ firmware on it?
Ideally I want the Quattro to be the center of my power system, it has run as a stand alone for over 6 years, all I'm trying to do is monitor a few things and as I upgrade the system, be able to monitor the changes.
I really don't want to replace the bomb proof and expensive Quattro, my funds won't easily run to that.
32 People are following this question.
