Is it so required that the parallel Multipluses not shown in VRM and victron connect i have two multiplus 5kv that dosen't show in both VRM and victron connect
It will show only one.
But if you look closer on the VRM -> Device list -> VE.Bus System you see the following line:
Hardware configuration | Two units configured in parallel |
After a correct configuration of course.
Via the Remote console you can also find both serial number..
Hope this helps
Rob
79 People are following this question.
