kim-hilding avatar image
kim-hilding asked
Charger don't charge sometimes
  1. I have a multiplus 1600. Lithium bat.
Sometimes the batteries don't take charge, it just says float on the multi control panel.
Often it starts with that everything is fine and the bats take charge, after 5-10h there is no charging any more. I try to turn the charger off and on but it won't help.
Any clues?
charger
We need more informations about your system.
What batteries? Any other components? Settings?
kim-hilding answered ·
3x90ah lfp from GWL, no bms. SBP 12 220. Mppt75/15, BMV 712 smart
When I switched the on off charger button on the multiplus the charging started again. Is it something wrong with multi control?
4 comments
Winston batteries? Have you programmed the multi to charge lithium batteries?
kim-hilding avatar image kim-hilding klim8skeptic ♦ commented ·
Yes, winston batteries, any problem?
I have not connected to a computer but I have placed the jumpers to lithium. Do I have to connect to computer, is there things that need to be changed that you can't manage by jumpers?
klim8skeptic avatar image klim8skeptic ♦ kim-hilding commented ·
@Kim_Hilding this Winston battery ?
If not, post a link to your battery.
It is Winston batteries.
Chargers.
