On my old 12/3000 Multiplus the trickle charge current was about 4 amps. Is it the same on the 24 volt model or just 2 amps?
Depends on the input and output voltages, and there will always be a certain amount of efficiency loss, but mostly yes.
So 4 amps, 24 volts? I am asking because I am going to convert the 24 volt trickle charger to my 12 volt start battery via a 24/12 Orion converter (with voltage output adjustment and low voltage switch). If the 24 volt MultiPlus puts out 4 amps doesn't this convert to 12 volts 8 amps? Asking because I want a proper size fuse. Thanks.
82 People are following this question.
