warick-wrx avatar image
warick-wrx asked
Using ESS with Multiplus 2 and Fronius Galvo
Hello
I would like to know if the using ESS on the Multiplus 2 with Cerbo GX and Fronius Galvo with datamanager card is possible. I see on the website it said it is not recommended. However I would like to know if it would work ? Furthermore would the frequency shifting settings in th asstant then work as desired.
thanks
Multiplus-II
rainerb avatar image
rainerb answered ·
Hello, until a year ago I had a 1-phase Galvo running in an ESS system for about 6 years (old Multiplus 3000/24V, Venus GX and ET340). The Galvo with LAN connection was recognized by the Venus GX and even the Zero-Feedin via network connection was working.
BUT there was an issue that sometimes the power control (GX to Fronius) did not work anymore. I found out that the problem was "solved" for one day, when setting the Fronius to "Standby" via an input of the datamanager card for a moment. Then I did this once every day automatically. I do not know whether this problem occurs with all Galvos or just with mine.
My Galvo (with 1,8kWp PV) was connected to the ACout of the Multiplus and frequency shifting also worked. I used the Fronius MG50 country setup.
Regards
Rainer
