danjwilko avatar image
danjwilko asked
Are my lead acid batteries about done?
Hi all,
I have a 24v battery bank consisting of 4 12v 115ah batteries.
i fully charged all the batteries with a ctek charger before hand and the. reconnected everything up.
I’ve set the battery bank capacity to 200ah for age of the batteries and not wanting to discharge past 50% too much.
Anyway the shunt was reset to 100%, and I’ve had it hooked up to the fridge freezer for the last day or so.
Image below shows from 94% didn’t quite fit the 100% frame in without making it all tiny.
The shunt is indicating 84% yet the batteries are already down to 24.3v.
I’ve tested the batteries for balance, 2 are 12.15 the other two are 12.20.
I’ve double and triple checked the setting for the shunt and the mppt.
Any help would be appreciated.
leisure batteries
JohnC avatar image
JohnC answered ·
Hi @Danjwilko
Those figures indicate no issues whatsoever to me. In fact they're holding up V better than my own do. But you've doctored the Ah, so can't compare really. You don't mention batt Temperature either, cold batts suffer V sag under load more than warm ones do.
I'd put your Ah setting back to where it should be, and treat them normally.
That Mid Point Deviation is a good thing to keep an eye on. A weak cell will soon jump that level way higher. You may not have the midpoint of your 2 batt strings connected, so you could move (or switch) that occasionally to check.
Charging them all as a 24V group might show issues that discharge won't.
7 comments
danjwilko avatar image danjwilko commented ·
Appreciate the info, I think it’s more that the depth of discharge figures for 50% are frequently talked about on the solar forum as being around 12.2v, so with the 24v setup I assumed 24.4v would be around that figure. Which made me think with the voltage dropping down to that level something might have been amiss.
Or am I missing something on the voltage front?
The midpoint is connected and so far hovers around the same % during discharge, stays around 0.2% when sat resting, but on charging I have seen it spike to around 1.9% but settles down soon after.
Il try switching occasionally to see if we do get any issues.
The batteries are kept indoors, which the room temp hovers around 16-18C
JohnC avatar image JohnC ♦ danjwilko commented ·
@Danjwilko
Take care what you read on the webs. V is a coarse guide only. And a 50% SOC in my real world is useless for anything more than a trickle load under alarm conditions. 75% for me is as low as I budget for, and 70% is an absolute emergency.
I've a well tuned Smartshunt, and recommend you put your worries towards setting that up correctly. You need to be able to trust something, but V isn't up there for me.
danjwilko avatar image danjwilko JohnC ♦ commented ·
So added the additional 2 batteries in, set the ah to 345 (6 115 batteries wired into 24v).
Looks like it holds up fairly well, so voltage will read a little lower than being stood, they do have a 0.5amp constant draw due to the inverter and ancillaries.
I think I’ve got the shunt set up properly from info I’ve read.
I thought the voltage would drop off more the lower the state of charge went but seems to be holding up well around the 24.4-24.2 region given that the fridge/freezer draws 100-200w so 5-10 amp periodically.
Thanks for the feedback @Danjwilko . Still looks normal to me. May they continue to serve you well..
christern avatar image christern danjwilko commented ·
Some notes.
Looking at the voltage to identify the state of your batteries is not that precise and assumes the batteries are left without charging/discharging for at least 24 hours. This is often forgotten.
I agree with @JohnC that you should focus on the shunt and its settings.
(I have stopped using Ctek-chargers since they kick in full charging once connected and with my usage, where I connect my boat once a week during winter, they start a new charging schedule every time. They also use a function of increasing the voltage a short time every now and then to learn how the batteries behave. This could damage the batteries. Instead I have started using a Victron Smart charger which I set in Power Supply mode at Storage voltage (13,2V) during winter. A safer way to keep my batteries healthy.)
danjwilko avatar image danjwilko christern commented ·
yes very true, regarding resting voltage I did wonder when your technically supposed to take the reading.
I do try keep tabs on it but with the constant use with the appliances it makes it difficult.
Now the supply feature sounds a great feature, I’ve literally just bought a noco genius 5 to assist charging all the batteries every one in a while for balancing purposes, which I know the 10 has the supply feature but it doesn’t play well with long term supply and usually shows faulty battery after a few days, anywho I will return the genius 5 and look into the victron smart chargers would you stick with a 12v or go 24v considering that’s the what the bank as a whole is (didn’t even realise victron did them).
Will also have a look at a victron battery balancer while I’m at it.
I would go for the 24V. Definitely!
