jkb avatar image
jkb asked
Lifepo 4 charge with Multiplus
I would like to charge my Lifepo4 battery (24V) with internal BMS and without bluetooth with my Victron Multiplus 24/1600. Bulk/absorption 28.4 V and float 27 V or 26.8 V. It is recommended that the charger be switched off when the LFP is full. I can monitor with the Victron smart shunt. I read somewhere that you can stop charging at 100% SOC via a BMV702 and with the help of the virtual switch of the Multiplus. Is it really that bad to let the float mode do its job? So just leave the charger on.
fgingat avatar image
fgingat answered ·
I leave my charger on with my lifepo4 battery bank without any problem.
jkb avatar image jkb commented ·
Thank you!
