Thomas Jirsch avatar image
Thomas Jirsch asked
Multiplus II does not turn on until VE Bus unplugged shortly
I have a MP 5000, Cerbo GX, Smartsolar Charger, 280 16s Setup connected to grid.
The Multi is in Inverter Mode, everything is working fine.
If I turn off the Multi via Switch Position, 0 it will not switch on again until I unplug the VE Bus.
After the Inverter indicator lights turn green I can plugin the VE Bus again and all is running as expected again.
Everything is up-to-date, cables are original Victron and I have changed them.
Any idea why this happens? Where to start looking?
Multiplus-II
Mike Dorsett avatar image
Mike Dorsett answered ·
If the Device on the other end of the VE bus is not powered, then this will happen. If the other VE bus device is a MkII or MkIII, then there is a link setting inside that can change this.
Kevin King avatar image
Kevin King answered ·
I have the same problem. Tried 3 different ethernet cables including victron original. Also updated the firmware on both MP2 and Cerbo. Any fix?
pauldunn avatar image
pauldunn answered ·
I am having the same problem. Did anyone find a way to fix this?
This started happening to me after updating the cerbo and Multiplus 2 to latest firmware
eleusis avatar image
eleusis answered ·
bumping thread. If inverter is restarted due to firmware update it will not comeback on until can bus cable is removed for a few seconds and plugged back in. Any idea why this would happen? its a multipus 2 15kva
You are describing a different issue to this topic which is about vebus, not CAN. Suggest you open a new topic and properly document the setup.
eleusis avatar image eleusis nickdb ♦♦ commented ·
Sorry, I meant the VE Bus Cable. Inverter will not turn on again after a restart unless this is unplugged. Once unplugged MP2 instantly turns back on.
Not really a huge issue as its rare ity gets a reboot. Just thought it may have been a common issue and easily resolved.
nickdb avatar image nickdb ♦♦ eleusis commented ·
Does it report any errors?
