chsolar avatar image
chsolar asked
First time setup using to run USB-C Camera
In need of some assistance. I've purchased a SmartSolar 75/15 and i'm planning on using it to power a wireless USB-C camera. My question is, can I connect a USB-C female port directly to the controller load?
Any assistance is greatly appreciated.
MPPT Controllers
Mike Dorsett avatar image
Mike Dorsett answered ·
The output voltage from the load port of the MPPT will be the same as the battery voltage. If you USB camera is expecting 5V supply, you will need an adapter to convert the battery voltage (12?) to the camera voltage.
