leahmarc avatar image
leahmarc asked
BMV 712 discharge floor / SOC
Hi, I have 4 x 270 Ah AGM batteries in parallel / series giving 24 volt and 540 ah monitored with a BMV 712
I have the discharge floor set to 50% as I don't want my batteries to fall below 50%
I want this set up so the relay will activate my generator when the batteries fall to 50% charge
For this to be correct do I need to set the SOC to 50% also or does the SOC calculate its 0% to 100% from the discharge floor setting of 50%?
BMV Battery Monitor
pwfarnell avatar image
pwfarnell answered ·
The discharge floor is only used to calculate the time remaining figure. See
https://www.victronenergy.com/media/pg/SmartShunt/en/all-features-and-settings.html#UUID-a139a4fe-c67e-fb60-02f5-cb760de807fa
For SOC 0% = completely empty regardless of the discharge floor value. Therefore you need to set your generator relay to come on at 50%.
To add, afik it will alarm based on discharge floor
