Hi can the Multiplus2 48/5000 support 2 95mm squared cable on the DC side of the Multiplus so that’s 1 pos 1neg?
Thanks in advance as I’m finding it hard to get 70mm2 from my distributor at the moment
The manual specifies 70mm2 for up to 5M and 120mm2 for longer runs.
Your 90mm2 is nicely in the middle.
70mm2 cables are a bit tricky to install, but possible.
95mm2 would definitly be a challenge...
not sure if this works?! Maybe with special short cable lugs?!
81 People are following this question.
