I bought 48V due to my source limits and I am trying to wire this in RV in 2*120 configuration. Please refer to included wiring diagram. I am not sure what to do with input L2. Should be tight to L AC OUT 2?
Please confirm if the inverter looks like this? The picture below is for the MultiPlus-II 2x120V Inverter/Charger version.
It would appear that the model being asked about is a normal single MultiPlus II and not the model in the picture above. The normal MultiPlus II can supply 120Vac on both the ACout1 and ACout2 outputs, but it is a single phase output. RV PowerIn L2 AC cannot be connected.
Hope this helps.
That is very pitiful, since I bought it under assumption it is 2*120V split for RV. I guess it is luck of explanation that 48V is different from 12 and 24 V versions. And your documentation and support honestly sucks.
Hi, very few of us work for Victron; most just like Victron and try to help on the forum with what we know. I did not create the documentation.
It is possible to your load on L2 to the ACout2 when the grid is disconnected using a contactor. But this will be a single-phase setup.
80 People are following this question.
