adeart avatar image
adeart asked
VeConfig and CCGX setup aettings after Firmware Update
device-list.jpgScreenshot 2023-05-01 133648.pngScreenshot 2023-05-01 133810.pngI have just updated my MultiPlus firmware from v158 to v502, after update my system have gone into permanent overload and Fault and also AC Input is still displaying disconnected after the update
VE.Bus
nickdb avatar image
nickdb answered ·
Did you reapply the configuration after the update? The update itself will reset the configuration to default.
The GX will also need to be current.
4 comments
adeart avatar image adeart commented ·
No i did not completely, I seem to have lost all previous settings
adeart avatar image adeart adeart commented ·
Oh by the way, the CCGX is up todate with latest firmware, How do i get the settings
nickdb avatar image nickdb ♦♦ adeart commented ·
You will need to create a new configuration (if you don't have a copy of the old one) and apply it. Settings will depend on your configuration so that isn't something we can just recommend without knowing exactly what you have.
For ESS and supported batteries, there are guides here: https://www.victronenergy.com/live/battery_compatibility:start
adeart avatar image adeart nickdb ♦♦ commented ·
Thanks
These are my configuration
JohnC avatar image
JohnC answered ·
@Adeart
You'll need to clear that Fault state in the Multi first. You must have done this update with VEFlash, so make sure the MK3 adaptor isn't still connected. You could try a Redetect System (In the CCGX, Multiplus > Advanced).
I have tried a redetect, it does not work, Tried a total shutdown of the system and the Solar charger, still the same. I am contemplating a firmware roll back What do i do next???
