Hello
This is my first post on the forum. I want to use Victron, for my ESS. I invest in Multiplus II - GX with an EM 540 powermeter (RS485) suggested by my distributor.
After configuration a got very bad result! When we start the ESS assistant the power to the grid is regulated but very slow! With a very big delay and big span -100W - +100W range, when 0w is configured.
Why this delay?
I read already a lot on the forum, most of the users gives the powermeter as problem. But I invest in a new powermeter with an update rate of 100mS, instead of 500ms or 1000ms. (https://www.gavazzionline.com/em127.htm#:~:text=Both%20EM530%20and%20EM540%20feature,storage%20or%20EV%20charging%20applications)
I was wondered how the powermeter communicates with the inverter, Victron use the baudrate of 9600!?! Why?
Is Victron busy with creating any solution of this problem?
