fattony avatar image
fattony asked
MultiPlus relay governed by inverter state?
I currently have the programmable really on the multiplus (VE.Bus firmware v501) set to energise when the SOC on the battery reaches 80% this triggers a dump load so as to not waste solar production
The issue I have is that when the inverter is switched from invert/charger to off the relay no longer functions.
Is it not possible to have the relay function independently of the state of the inverter?
(I’am using VE.Configure assistants to program the relay)
Kind regards,
