thekock avatar image
thekock asked
Can I leave a Smartsolar MPPT 20/100 connected to my aux battery while driving?
Hi All! Just installed a new AGM auxiliary battery in my Hilux. I'm busy fitting a 300w panel and a SmartSolar 20/100 charge controller. The system connects the Start battery (Lead acid) to the Accessory battery on start up via a solenoid. can I leave the SmartSolar 20/100 permanently connected and charging while driving (and start up)?
MPPT Controllers
Mike Dorsett avatar image
Mike Dorsett answered ·
yes. The voltage limits in the MPPT will limit the charge current whilst driving, and our solenoid should isolate the battery whilst starting.
thekock avatar image thekock commented ·
My solenoid isolates when ignition is turned off and connects as soon as the ignition is turned on (before cranking). Will this be an issue for the charge controller?
