louis becht avatar image
louis becht asked
wiring diagram questions
20230423-150910.jpgI am new to solar power, I am certified industrial electric and a CFSEA master tech. looking for some peer or pro input, changes, suggestions on my solar system diagram before I start putting it together, enclosed is my list of parts and wiring diagram, Thank You In Advanced for your help.
my solar components
3) solar panels Rated Power 195 W
Solar Cell Monocrystalline
Maximum/Peak Voltage(Vmp) 19v
Open Circuit Voltage(Voc) 22.8v
Short circuit current 12.23A
Maximum current 10.27A
Epever: Tracer 6415AN 60a solar charge controller 48-12v max 150v 4500w (780w 12v) (1500w 24v)
Victron Energy MultiPlus-II 2X 120V, 3000VA 12-Volt Pure Sine Wave Inverter and 120 amp Battery Charger
1) 600a High Current Battery Disconnect Switch
1) 0/2/4 Gauge AWG in-Line ANL Fuse Holder with 150 Amp fuse
1) 0/2/4 Gauge AWG in-Line ANL Fuse Holder with 400 Amp fuse
1) 50a Miniature Circuit Breaker, 2 Pole 500V 50 Amp
2) DC Miniature Circuit Breaker, 2 Pole 500V 40 Amp Isolator for Solar PV System
1) DC Miniature Circuit Breaker, 2 Pole 500V 20 Amp
3) 250A Circuit Breaker Manual Reset
1) 60a Premium High-Current Circuit Breaker
1) 80a Premium High-Current Circuit Breaker
1) 150a Premium High-Current Circuit Breaker
1) DC Multifunction Battery Monitor Meter,0-200V,0-300A (Widely Applied to 12V/24V/48V RV/Car Battery) LCD Display Digital Current Voltage Solar Power Meter Multimeter Ammeter Voltmeter
2) Busbar 1 x 3/8” Stud 2 x #8 Screw Terminals Power Distribution Block
2) Busbar 4 x 3/8” Stud 2 x #8 Screw Terminals Power Distribution Block
50ft 8 AWG 25' red 25' black
25ft 4/0 Wire (Red Translucent) Copper Clad Aluminum CCA - Primary Automotive Wire
20ft 10 AWG Silicone Wire Kit Red and Black Each 10ft Flexible 10 AWG Stranded Tinned Copper Wire
50ft)6 AWG Wire (25ft Each- Black/Red Translucent) Copper Clad Aluminum CCA - Primary Automotive Wire
10ft) 2/0 Gauge 5 Feet Black 5 Feet Red 2/0 AWG Ultra Flexible Welding Battery Copper Cable Wire
6) ECO-Worthy LiFePO4 12V 100Ah batteries
12,8V voltage 14.5V maximum voltage
100A maximum discharge current 50A maximum charge current
Temperature range (discharging) -20-55 degrees Temperature range (charging) 0-55 degrees
wiring diagram
mvas avatar image
mvas answered ·
Regarding the Battery Pack ...
1) Does the manufacturer recommend six (6) batteries in parallel?
2) Does the manufacturer approve of your battery-to-battery parallel cabling schematic?
