lonebeagle avatar image
lonebeagle asked
BMV 700 displays incorrect voltage
Good morning,
I have 2-24v LiFePo4 in series to power an Elco 48 volt motor. My BMV only displays the voltage of one battery ~26.6 volts. I have set the system voltage to 52 volts via the connect app but the displayed voltage doesn't change. Any help would be greatly appreciated.
BMV Battery Monitor
klim8skeptic avatar image
klim8skeptic answered ·
@LoneBeagle you need to wire the shunt as per diagram 7 of the Quick Start Guide.
Make adjustments as per set up your BMV video.
lonebeagle answered ·
Thank you!
I have a 24 volt Blue Smart IP67 Charger on each battery is that going to cause a problem?
Thanks in advance,
John
@LoneBeagle I have a 24 volt Blue Smart IP67 Charger on each battery is that going to cause a problem?
It will cause problems as the shunt cant see current going back into the batteries.
Is the IP67 charging with the standard Li-ion battery profile / settings?
Do you have mid point (battery) monitoring hooked up / enabled?
The IP67(s) have the profile that came in the box. I will go check it shortly.
There is no mid point monitoring set up.
I am at the point where I need to back up and start over. Thanks for your help & I will post the results after I get it redone
