Just got my multiplus running but I am getting low battery shut down for some reason.
Whe solar MPPT is switched off the inverter runs all ok. I have pulled 50 amps for a few min with no issues.
With the MPPT switched on as soon as I put any load over 10 amps the inverter shuts down with low voltage warning.
So I am assuming this is an MPPT issue. See attached MPPT setting. I am wondering is this is an overvoltage from the MPPT as some times it shuts down the battery BMS
