I'm keen to use the new Quattro II 5000 24volt version in a current project. Cleary, it is designed to be mounted vertically with the cable outlets at the bottom. This is the same, in principle, as the earlier models. However I would need to mount the unit either :
A / Horizontally, lying on its back with the front panel upwards
or B/ Vertically, but lying on its side, rotated 90 degrees, so the cables exit from either the left hand or right hand end of the installed device.
I have installed earlier versions horizontally, with the front panel upwards, but need to know what I can do with the Type II units.
