immanuel-cordes avatar image
immanuel-cordes asked
One out of three daisy chained MPPT’s doesn’t show up
Hi everyone,
I have the problem, that one out of three daisy chained smart solar MPPT 250/85 doesn’t show up in the device list. All of them are connected to a Cerbo GX. The first time I connected them, this particular one was at the end of the daisy chain. Also the rotary switch was set to 5, which I set to 2 afterward.
Even if I put it in the middle of the chain, or just connect it by itself I doesn’t appear. I terminated the VE. Can on both sides.
Other than that, it works normally like the other ones. I just cannot see it in the VRM even though it feeds energy into the system.
Thanks for your help!
MPPT Controllers
Paul B avatar image
Paul B answered ·
this is of course using ve can
does it read if you use the ve direct connection,
are all the settings in each unit set to a diferant canbus instance, you should not have two devices of the same type with the same instance
immanuel-cordes answered ·
Thank you for your answer.
What do you mean by “a different Can Bus instance”?
How do I set the Can Bus instance?
I fixed the issue by disconnecting the Batterie and the solar panels. After I connected everything again it worked.
