Hello, can someone tell me how to load modules at startup?
I found this:
We do not want to load i2c-dev
manually everytime the Raspberry has booted, so we write the module name in /etc/modules
but the folder modules dont exist.....
I found this:
/etc/modules is a file
create the modules file and put i2c-dev on a line
root@raspberrypi4:~# touch /etc/modules root@raspberrypi4:~# echo i2c-dev > /etc/modules
Wow, thank you.... ! ;-)
Maybe you know also, how to install the ADS1115 driver? I dont got it working, I found only APT installer manuals!
@buddhafragt I don't think the driver is included in venus-os, so you need to install gcc with accessories and git on your raspberry pi, git clone the driver for your device, compile the module and install it.
EDIT
It's probably half a year since I set this up on my pi with i2c devices, and it has worked flawlessly, so have forgotten a lot.
If I remember correctly, you don't need to install the driver, but talk directly to the devices via the i2c bus using, for example, python or a C program, but I mean to remember that they also had to be compiled. You can also communicate directly using smbus.
Surely someone here knows more about this than me.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
64 People are following this question.
