mateaco avatar image
mateaco asked
Grounding question
I have a lynx power in connected to a lynx distributor, all the positive and negitive bus bars are filled on the distributor and it is grounded to the chassis, I have used one of the pos/neg bus bar slots on the power in. Do I need to ground both the lynx dist. and the lynix power in to the chassis?
Grounding
kevgermany avatar image
kevgermany answered ·
Not needed. And if you do you create an earth loop, which can lead to noise problems.
