I have an issue that I am hoping you can help with on a Multiplus II that I recently installed in my RV. Yesterday I tried the system running the generator for the first time. Warmer weather finally blessed Sacramento so I was looking forward to training the Micro-Air Easy Start.
Here is my issue... I had the inverter set to Charger Only and as soon as I turned on an air conditioner the Multiplus shut off completely and then cycled back on about a minute later allowing the AC line in to work as it should. I tried several times and each time it was the same result. Next I tried it with the Multiplus set to inverter and again it shut off the AC line in from the generator like before but continued to give power via inverting with the batteries. After about a minute it resumed the AC from the generator.
Is there a setting I need to change or is this a defect that needs to be addressed?
