kent2ben avatar image
kent2ben asked
DVCC - Maximum charge voltage (while feed-in)
Hi
I use "Maximum charge voltage" to override the BMS and set a lower charge voltage.
It works fine but...When I turn on "Feed-in" it adds 0.2 volt to the max charge voltage?!
As you can see here I have set it to 27.4v in DVCC.
But in the MPTT "Networked operation" the "Charge voltage" is set to 27.6v
I see the same pattern no matter what voltage I set in DVCC. It is alway 0.2v above DVCC.
If I turn off feed-in the voltage is spot on?!
Anyone who know what I am doing wrong ?
DVCC
baxter avatar image
baxter answered ·
There is nothing wrong. To provide feedin the charge Controller are allowed to work on a higher voltage, up to 0.4V above CVL. This is also described in the DVCC Manual
kent2ben avatar image kent2ben commented ·
Tanks!
