Hi I need to know how to set the charge voltages on my none bluetooth enabled Orion -tr 12 12-18 this may just be pointing me in the direction of the manual
The normal non-smart Orion are NOT designed as battery chargers. They are just DC to DC converters with a constant voltage output.
Not true, because the Manual and the Datasheet say clearly, the ADJUSTABLE Orion-Tr can be used as charger.
I have the 24/24-12 (non-smart) bought, befire the DC/DC Charger existed, hence I use my one since 5 years now, but it is VERY hard, to use 3 of them in parallel and get on each of them the same Voltage with the small Trimmer in the Orion-Tr
The non-Smart Orion-Tr is not intended as charger.
https://www.victronenergy.com/dc-dc-converters/orion-tr-dc-dc-converters-isolated
I guess most didn't so Victron reworded.
37 People are following this question.
