Todd Wackford avatar image
Todd Wackford asked
Change 12|3000|120 Multiplus back to grid "None" in VEConfig - How?
Yesm I should have created a backup default config file but I didn't. Anyway, I was wanting to look at the different settings for the system for ESS, so I chose "Country / Grid code Standard - Other" and uploaded that to the Multiplus. Now I want to go back to "None" but it wants a password.
What is the password, or is there another way to revert to default VEConfigure?
TIA
boekel avatar image boekel ♦ commented ·
You can get the password from your distributor. (I've emailed it to you.)
Paul B avatar image
Paul B answered ·
easy way is reinstall the firmware and or update the FW and that will reset it to default settings,
note any past changes will need to be redone
