When paralleling two quattros, do you have the combined power assist of both quottros when running shore power or a generator?
This is my current set up
This is what I would like to upgrade to.
Yes in parallel they will both assist.
The input current you set on the GX should be split over the two units if set up correctly.
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
32 People are following this question.
