Hello I've an MPPT 100/30 and it only charging my battery onices then just saying it full? I needed to unplug the slower MPPT and then replug it for it to charge onice more any helps would be amazing peace ✌️
The slower mppt? So you have more than one. Maybe your battery does not need the charge.
Does the battery voltage drop?
Usually a battery will be charged, then drop to float. A new charge cycle only begins after it drops below float past the rebulk value.
If it does not then it will not charge again.
To customize the rebulk see these instructions.
Hi I have two L35-110 Avon leisure battery that are linked together as one. Here is screen shot of what the MPPT it is showing full battery when it's flat
At13.8V, the battery isn't flat, it's full.
Please post the other screen shots as requested.
Why do you say the battery is flat?
Sorry forgot to take screenshot of battery page will take one tomorrow when sun is out it is say 13v but it's giving out wrong reading I know the battery are flat because I have checked them with a multimeter
Here are the screen shots of my battery settings thanks for all your help guys this my first time doing anything solar solar so totally new to this
@MCMatthias given your mppt reads 13.8v, and your battery reads 12v, there seems to be a disconnection between the mppt and battery.
Please check your fuse / breaker and cabling between the mppt and battery.
Still had same issue only one charge gonna unplug everything else so it's just solar and battery to see if some is interfering with the reading
34 People are following this question.
