I am having some questions about my inverter its a multiplis II 12/3000/120. Last night, i unplugged shore power and had an immediate total power failure in the bus. Everything restarted on its own, but since then, operating on my battery bank which is 800ah of renogy lifepo4 batteries, i get intermittent power failures, specifically when drawing power for the air conditioning. The ac will start and run for a few minutes and then the multiplus will cut off, showing a red low battery indicator on the display panel. After about 10 seconds the system auto restarts, shows no faults or alarms. I know my battery bank is completely charged because i have 13.3 volts holding in each battery. Any ideas what could be causing this? I hooked back up to shore power, and no issues now, a/c is working and no shutdowns, so it seems to be an inverter issue? Why would it think the batteries are too low? The a/c only draws about 750 watts when running.
