Michał Kata avatar image
Michał Kata asked
Grafana problem - 3 phase data
I have a problem how to display data from 3 phase system ? ac loads or pv production ? The formula NumberOfPhases dosn't work or I 'm doing some mistake, anyone can help with that ?
grafana
hominidae avatar image
hominidae answered ·
...ehhrr..not quite sure where your problem is, here...but in a three phase system, the "(total) Number of Phases" is "3"...comes natural ;-)
The values for Curent and Power, for each individual phase, can be found under:
..../Ac/Consumption/Lx/Power and .../Ac/Consumption/Lx/Current (change Lx to L1/L2/L3 respectively)
5 comments
Michał Kata avatar image Michał Kata commented ·
I tried this and still doesn;t work, whet put this formule it shows no data :
hominidae avatar image hominidae Michał Kata commented ·
it is either L1, L2 or L3 in the path...not "L1/L2/L3" ... try this for L1: ....Ac/Consumption/L1/Power
Note: I don't know your complete path, do not copy the leading "dots" in my example string.
If that doesn't work, I can't help as I am organising my datasets / measuremenst in influxdb differently, so my example queries wouldn't help you.
Michał Kata avatar image Michał Kata hominidae commented ·
Yeah of course, this path works for single phase, but I wont the Sum of all 3 phases like is on VRM portal
Do you have a grid meter? Than use: https://github.com/victronenergy/venus/wiki/dbus#grid-and-genset-meter
Otherwise, there is more than one way to do that in grafana, depending on the Version deployed, for an exampe that might help ,see: https://community.grafana.com/t/summing-2-series-results-to-a-single-value/46696
in that way i can only display 3 separate measurments :
You didn't read the other response...use a transformation to combine these three field into a single one.
Here's a quick example, combining all Power Values (Battery, Grid, PV) from my site into the SUM (of all power values) - just as an example, as technically it does not make much sense, doesn't it:
I short:
  1. Create a "normal" query for each field.
  2. select the "last" value
  3. group by "fill(previous)
  4. give each query an Alias Name
...then create a simple transformation of type "add field from calculation" like this:
in short:
  1. type: add field from calculation
  2. field name: select the Aliases, that you wish to be part of the calculation
  3. Type of Calculation: "Total".
  4. optionally, give the new field an Alias- Name to be displayed (default will be "Total").
now, use your existing queries for L1, L2 and L3 accordingly.
Hope this helps.
Thank you so much for your explenation, now it works very very well, thanks a lot
