Hi
My Caravan has on-board charger so it charges the battery when plugged in to AC.
Im planning to install my MPP and Solarcell and connect to the 12V Lead battery.
Are there any risc's or dont's to have this setup ?
Hi
None if you fuse correctly and have pv disconnects. And a way to isolate loads.
Remember your dc loads are limited to the 15A max output of the load port on the 75/15.
Tp take better care of your lead acid battery a BMV is also recommended.
Hi Alexandra
I'm a beginner in this area but hope to gain more knowledge.
I have a fuse between MPPT and Battery (+ side) and DC load will only be a Mobile charger.
What did you mean by "pv disconnects" ?
Did not understand "Tp take better care of your lead acid battery a BMV is also recommended." can you please clarify ?
35 People are following this question.
