camper2430 avatar image
camper2430 asked
BMV-712 - Inaccurate data, bluetooth issues and head unit flickering
I have three main issues:
Issue 1
I set up my BMV712 a few days ago but it is indicating weird data. My setup is 120Ah lithium battery, Redarc 1225DC charger, no solar connected and no other load connected at moment. I have all load negatives to shunt load and only the aux battery negative to the shunt negative.
Below is a picture of the SOC after I reset it manually to 100% and it apparently drained after 5m - Yet i know the battery is near fully charged.img-5833.png
Issue 2
The bluetooth conneciton is also very inconsistent - sometimes it lets me connect and other times it fails at 20%.
Issue 3
The head unit appears to "flicker" so much that I cannot read the data. Do I need to replace the RJ12 cable?
Thank you for any assistance.
BMV Battery Monitor
@camper2430 Could be a dodgy fuse or fuse holder, check, clean and tighten.
The fuse should be a 0.5 - 1.0a unit.
camper2430 avatar image camper2430 klim8skeptic ♦ commented ·
Thank you for the advice. I will try that out.
