donshaddarnur avatar image
donshaddarnur asked
BlueSmart IP65 Charger 12/10 - Error Codes?
Hello everybody,
my new charger work only one day, now it doesn‘t work. No funktion. When I push and hold the „Mode“ button, the three blue LEDs and the three lower yellow LEDs blinking 3 times, then pause and so on.
If there an error code list to check the blinking code?
It is connected to a LiFePo4 battery. The charger is in the lithium mode before the first connect.
Many thanks.
Best regards,
André
charger
donshaddarnur avatar image donshaddarnur commented ·
PS: When I disconnect it from the battery, there is the same issue. Disconnect from 230V and connect after 60 seconds, the same issue again.
donshaddarnur answered ·
any ideas?
Thanks André
