quantumquest avatar image
quantumquest asked
Where can I find G-ST18i connectors?
The MultiPlus Inverter/Chargers from 500VA to 1600VA use "G-ST18i" connectors for AC connection, but I can't find this connector anywhere. I found some "GST18" but they are still quite difficult to find and I'm not sure they are the same connector.
Where can I find "G-ST18i" connectors in Europe? And why did Victron choose this rare connector?
klim8skeptic avatar image
klim8skeptic answered ·
@QuantumQuest My inverter / charger came with a matching pair of GST18 plugs, maybe yours will too.
I bought an GST18 extension cable from RS Online because I couldn't be bothered sourcing 2m of 16a mains cable.
theo74 avatar image
theo74 answered ·
As far as I could find, the difference between a GST18 and GST18i connector is de maximum current they can handle. GST18 is 16A/230VAC max and GST18i is 20A/230VAC max. For the rest they are identical.
The GST18 connector is quite common to use in the EU, and I think even outside the EU. And they are not hard to find. For example you can find them at webshops like RS-Online, Amazon, and Conrad. Just be aware that there is a Female (power) and Male (load) version, when you order.
quantumquest answered ·
I asked a vendor and they confirmed Victron provides GST18 plugs with these MultiPlus. That should be good enough.
theo74 avatar image
theo74 answered ·
The Multiplus inverters with GST18 In/Out indeed come with a male and female GST18 connector.
I actually thought you wanted to have some extra connectors. Anyway, have fun with your Multiplus.
