can I combine 75/15 with 100/30 mppt Victron controllers?
Thank you!
Thank you!
By combine to charge one battery, yes.
You do need to check if your battery should be charged with 45amps.
No. Each must either be connected to the battery terminals, or to a bus bar that is then connected to the terminals.
And there should be battery cable fusing. As well as a way to disconnect the solar panels feeding each mppt.
80 People are following this question.
