groningen avatar image
groningen asked
MPPT 30% over panelling rule or can we go higher?
Dear All
I would like to know if the 30% over panelling is "set in stone".
Lets say I use a 150/45 MPPT. If I install six (6) 600W, the total will be 3600W.
The spec from Victron is 2600W, however, the VOC will be +- 120V.
Will this be OK i.e. the MPPT will clip the amps during summer, but in winter, I will benefit of the over panelling?
MPPT Controllers
JohnC avatar image
JohnC answered ·
Hi @Groningen
No, it's not set in stone. For example if you were to use 12V batteries you'd be overpanelled by some 600%. And it would still work fine.
But don't exceed the Voc and Isc limits with the panels.
@Groningen
As @JohnC said.
You can do what you like as long as you don't break the input current limit and the input VOC limit at minimum temperatures.
groningen answered ·
@JohnC @Alexandra
OK, thank you for the clarification.
