I have a 200A Lifepo battery attached. It works fine. The minimum cut-off for the battery is 10.8v
Can I simply interface and make the changes? IE set the Multi to Lithium battery and set the minimum to 10.8v?
No other changes need to be made?
77 People are following this question.
