Hi i have the blue solar 100/20 with a explorer 220ah agm battery and 245w panel. Could you tell what setting the battery type should be on please.
I'm my opinion, your charge controller is a bit small for the Panel. If the panel does actually produce 245 w it will be at the limit of that controller.
Hi, how is your system working? I have a similar set up of 285 W panel, 100/20 controller onto 210Ah leadacid. My reading says that the panel is 36v. Is this right?
12 People are following this question.
