Joe avatar image
Joe asked
Keepalive via NodeRed to Venus
All,
for establishing a MQTT based solution for a power reducer box I am step by step getting there.
Sending an R/<ID>/keepalive even with filtering for example to ["settings/#"] works from scratch via MQTT broker, but I am not getting it up with NodeRed. As I want to shoot every 60 seconds, Node-Red would be the perfect solution.
It can only be a "JSON Format" issue, but whatever data format I chose (string, JSON, ..) it does not work.
Can anybody please educate me, what I am doing wrong? I have literally tried everything (with brackets {[]}, w/o, etc.
Venus OSNode-REDMQTT
marc-hd avatar image
marc-hd answered ·
Dear Joe,
this is my very first answer in this forum. So don`t be too harsh to me;-)
All information about the keep-alive of the mqtt broker of the victronOS you'll find at: https://github.com/victronenergy/dbus-mqtt.
I send the keep-alive within a Node-RED flow (attached at the end of my answer).
XXXXXXXXXXX
needs to be adopted to your venusOS installation. As well as the broker address:
"broker": "XXX.XXX.XXX.XXX",
which corresponds to the ip-address of your venusOS. BTW in my case it is a venusOS on a Raspberry PI.
The main difference with the suggested:
  1. msg.topic = 'R/cxxxxxxxxx4/keepalive'
  2. msg.payload = ''
  3. return msg;
is:
I only "request" the topics I am interested in. If you send only an empty string as payload you'll get ALL topics send.
The payload needs to be a json list as listed below:
"payload": "[\"system/0/Dc/Battery/#\",\"system/0/Ac/Consumption/#\",\"system/0/Timers/#\",\"battery/1/#\",\"solarcharger/#\"]"
The topics I am interested in I checked manually with the complete topic-list:
(I personally do NOT use Microsoft products... so this is done on an xterm)
mosquitto_pub -h XXX.XXX.XXX.XXX -m '' -t 'R/XXXXXXXXXXX/keepalive
mosquitto_sub -v -I myclient_ -t "#" -h XXX.XXX.XXX.XXX > all.txt
In all.txt ALL topics are collected.
Some screenshots:
node-red-keepalive-victron-1.pngThe flow.
node-red-keepalive-victron-2.pngThe list of topics.
node-red-keepalive-victron-3.pngInterval set to 50 seconds.
I hope for someone is this post usefull...
Best regards
Marc
        "id": "11e7538c7954de75",
        "type": "tab",
        "label": "keepAlive",
        "disabled": false,
        "info": "",
        "env": []
        "id": "9f8ba7eb9957abd1",
        "type": "inject",
        "z": "11e7538c7954de75",
        "name": "keepAlive",
        "props": [
                "p": "payload"
        "repeat": "50",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "[\"system/0/Dc/Battery/#\",\"system/0/Ac/Consumption/#\",\"system/0/Timers/#\",\"battery/1/#\",\"solarcharger/#\"]",
        "payloadType": "json",
        "x": 230,
        "y": 160,
        "wires": [
                "34c4a2c6e0eeda47",
                "c234e95aac810b09"
        "id": "34c4a2c6e0eeda47",
        "type": "mqtt out",
        "name": "",
        "topic": "R/XXXXXXXXXXX/keepalive",
        "qos": "2",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "0aa70d5af5427c60",
        "x": 660,
        "y": 160,
        "wires": []
        "id": "c234e95aac810b09",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 600,
        "y": 240,
        "wires": []
        "id": "0aa70d5af5427c60",
        "type": "mqtt-broker",
        "name": "VenusOSmqtt",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
Joe avatar image Joe commented ·
Marc, even though we're both German, let's keep it English:
YOU ARE MY HERO!
The solution is:
- Send payload with inject, keep format as per official Victron docu: ["settings/#"]:
- Send topic in MQTT-Out and NOT in inject:
Result, captured w/ MQTT Explorer:
So, keepalive request send from Node-Red, limited to the topics of interest which means my FHEM server doesn't get killed ;)
marc-hd avatar image marc-hd Joe commented ·
Dear Joe,
I am happy that the stuff I wrote was helpful.
Have fun,
Marc
becker avatar image
becker answered ·
kannst du die Frage im deutschen Bereich noch mal stellen ? Verstehe nicht was du da machen willst.
erledigt...
gerard-van-seventer avatar image
gerard-van-seventer answered ·
I use a (very) simple function node which is triggered every 20 seconds (could be a little longer).
msg.payload = ''
return msg;
Joe avatar image
Joe answered ·
Thank you Gerard!
What format is the data you send? String, JSON, ...?
How to get the return msg in Node-Red done?
The keepalive is just to tell Venus to keep sending MQTT messages. If you don't the MQTT messages are cleared after a short amount of time.
I use an inject, a function and a mqtt out node. There are no return messages on a mqtt out node.
screenshot-2023-03-17-221332.jpgIf you want the read values on node-red you have to use a mqtt in node and subscribe to the topic you want and read the values you are interested on.
