stsl avatar image
stsl asked
How is the GX in a MultiPlus II GX powered?
I have a question that might be somewhat odd. I have a MultiPlus-II GX installed and as I understand, it's a "normal" MultiPlus that also contains a GX device, similar to a Cerbo GX.
The question is: is this "internal" GX device powered by the battery (DC) or by the inverter (AC). In other words, when I shut down the inverter (e.g. by going to "charger only"), would the GX device shut off if there was no AC input, only battery DC input?
Multiplus-II
Jons Collasius avatar image
Jons Collasius answered ·
AFAIK it's hooked up internally to the Battery Port
mr-manuel avatar image mr-manuel commented ·
How is the GX device then powered, if there is no battery? For testing I connected only AcIn and the GX is powered. Does the MultiPlus-II provide power on the battery port, even if there is no battery?
sharpener avatar image
sharpener answered ·
AFAIR that is why you should turn on the battery input and wait for the Cerbo to power up before turning on the AC.
