denzel avatar image
denzel asked
MPPT Over paneling
Please can you advise, I want to know if i can add more panels to my setup below ?
Setup :
3 * 24V/3000 Multiplus 1
3 * 250/100 MPPT
I have 5 panels on each controller, with a total voltage of 228V, which means i have 22V capacity remaining. Over the past 90 days "summer" i never went over 194V per controller. Can i add more panels to take me to 250V? What will happen if my Voltage exceeds 250V? Victron recommends over paneling by 30% does this also refer to the PV Voltage ?
MPPT Controllers
Alexandra avatar image
Alexandra answered ·
@Denzel
No. The 250v string is a hard limit. 194v is the panel under load and that is not the voltage used for sizing.
You can add a second string to the charge controller (of exactly the same config).
Then your set up will be over sized without breaking the input current limit or the VOC limit.
