I've tried to investigate other answers before asking, but I'm not 100% sure. I think this is relatively simply. Can I parrallel my 2 x 100/50 MPPT's so that I don't have 2 separate cable runs to my Lynx ?
That is something I would not do. I am paralleling 2 Victron 150/70's but I have each running to a position on my fused Lynx PowerIn. Since it is a good idea to use a larger than reccomended AWG for each controller to begin with, I doubt you are going to find a wire/cable sufficient for the actual load that will also fit the terminals in the CCs.
I suggest you rethink your idea.
It's ok to do this, so long as you stay within the cable current limits (mc4 connectors max 30A). You can get Y cables specifically for this.
Personally I'd run two cables to a single input on the Lynx.
Are you trying to parallel your CC's into your system via a Lynx PowerIn or Lynx Distributor?
At some point in your system each CC's wires have to be connected into your system.
What exactly are you trying to do?
81 People are following this question.
