kent2ben avatar image
kent2ben asked
Inverter/multiplus makes voltage fluctuation in BMS measurements
Hi
I hope som of you can help me with my problem.
My setup
- It is 24v
- 4 x MPPT 100/50
- 1 x Multiplus ii 24/3000 (connected ESS connected to earth)
- JKBMS 8S 280AH
My problem
I have som strange voltage fluctuations on specific cells according to my BMS (A meter shows stable voltage)
As you can see cell 7 is all over the place (blue line) and this is with 300-400W load on the multiplus inverter + the mppts are charging.
(you can see the load amps in the graph)
I tried replacing the balance leads with no effect.
Then I tried turning off the multiplus and only charge with the mppts.
And then the fluctuations despaired?
Info about my JKBMS
Do any of you have an idea of what is happening?
Can the inverter make some kind of noise running back to the BMS ?
Can I connect the BMS/battery too close to the inverter ?
Multiplus-II
